An attempt to remove an L2VPN instance from a tree ordered by VLAN instance failed. The instance may have already been removed, in which case there should be no impact; however, there could have been data corruption, in which case this L2VPN or other L2VPNs may not function properly.
There is no workaround for this error.
Error
Removal of L2VPN instance with id %id% from the VLAN tree failed (%reason%).
| Name | Type |
| id | uInt32 |
| reason | sInt |
